6 Users Online (5 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Find&Replace revit Components - is there an option like that?
Mon, Jun 24, 2013 at 9:12:39 AM | Find&Replace revit Components - is there an option like that?
danezeq
i found that trees in my project are so heavy - and now found a light tree - that renders good.
 can i replace all of them in one click?
Mon, Jun 24, 2013 at 9:51:55 AM | Find&Replace revit Components - is there an option like that?
coldslogan
yes... you should be able to select all in view, then change together....... if you right click on the tree type you want to change then hit select all in view. you should be able to change them simply then.... the other way would be to use the filter, check none then select the trees that way Smile much the same way you change a wall type
Mon, Jun 24, 2013 at 7:25:03 PM | Find&Replace revit Components - is there an option like that?
danezeq
Thank you very much! i will try that now.
in this manner, maybe i should start replace heave components with autodesk official components with are lighter.
is there anyway in revit to see all the project components sorted by file size (or memory consuming) ?
Tue, Jun 25, 2013 at 7:25:19 AM | Find&Replace revit Components - is there an option like that?
No, you can not list them items by size.
Find & Replace
Mon, Feb 22, 2010 at 9:27:05 AM
14
Find & Replace???
Sun, Oct 16, 2005 at 5:54:15 PM
Find/Replace Text
Tue, Dec 23, 2014 at 1:33:02 PM
Find and Replace Text Command
Wed, Oct 18, 2006 at 12:25:13 PM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 7.0199
