Forums >> Revit Building >> Technical Support >> Cut Wall Back
Mon, Jun 24, 2013 at 5:52:26 AM | Cut Wall Back
amok
Hello there,
I’m trying to cut a wall back to line in with a slab, see attached, and I cannot figure out how to do it. Normally I would use a model in place void to cut with but I can’t get it to work. I feel that I’m missing an obvious trick here!
Does anyone have any recommendations? Any help is really appreciated thanks!
Cheers
Mon, Jun 24, 2013 at 7:39:05 AM | Cut Wall Back
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What you are pointing to does not look like a wall, it looks like an isolated footing to me.  What exactly is it?
Mon, Jun 24, 2013 at 7:47:19 AM | Cut Wall Back
amok
Hi Teafoe,
It’s a wall with a sweep on the bottom to create the retaining footing with. Actually thinking about it I should have used a wall foundation but hey, I’m still learning and I was underpressure!
Cheers
graphical cut back distance
Thu, Aug 19, 2010 at 11:14:35 PM
Precast Plank Showing as cut
Fri, Dec 28, 2012 at 1:04:13 PM
Wall Build-up (peeled back)
Wed, Dec 23, 2009 at 8:02:58 AM
How Do I Cut Out Part Of The Wall?
Wed, Apr 22, 2009 at 5:30:18 PM
Wall Sweep Doesn't Completely cut
Tue, Jun 19, 2018 at 10:47:01 AM
Page generation time: 1.1115
