Forums >> Revit Structure >> Technical Support >> Copy/Monitoring Arch Walls Help !!
Sat, Jun 22, 2013 at 11:02:36 AM | Copy/Monitoring Arch Walls Help !!
hoythunter12
We are working on a project and as usual the architect sent us their model. Is it best to copy monitor their walls into our project. I have successfully C/M their levels, and now my main concern is to have a physical wall to put a wall footing under.
My question is, would it be better to CM their walls > change to structural > then put wall footings under them. Or would it be more efficent to simply link in their background and add our own footings underneath them. I know this would not update their furture changes. Any input would be very appericated, have not done this before and I would really like to know the most efficent way to do this.
Thanks
Need help with Copy/Monitoring
Tue, Apr 1, 2014 at 12:54:53 PM
Copy Monitoring Walls - Downspouts
Fri, Feb 28, 2014 at 9:27:42 AM
Problems Copying Walls from Linked Arch Plans?
Wed, Jul 15, 2009 at 4:23:32 PM
Errors while trying to Copy Monitor
Wed, Nov 15, 2006 at 8:55:06 AM
structural walls copied from arch
Fri, Aug 21, 2009 at 6:49:55 AM
Page generation time: 2.7174
