Forums >> Revit Building >> Technical Support >> linked revit structure.rvt
Fri, Jun 21, 2013 at 9:36:48 AM | linked revit structure.rvt
clittle1230
I am trying to get my linked structure.rvt to show the joist in my plan views. I can see it in a 3D view but not on the plan views.I have tried all my visibility options but nothing is working.
Thanks
Fri, Jun 21, 2013 at 9:43:30 AM | linked revit structure.rvt
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'd assume its a View Range issue.
Fri, Jun 21, 2013 at 9:53:41 AM | linked revit structure.rvt
In plan view - show us the VG settings.
Fri, Jun 21, 2013 at 9:54:13 AM | linked revit structure.rvt
clittle1230
I have set my view range to unlimited and it still will not show anything
Fri, Jun 21, 2013 at 10:05:44 AM | linked revit structure.rvt
clittle1230
How do I show VG setting and which ones are you looking for?
Fri, Jun 21, 2013 at 10:24:13 AM | linked revit structure.rvt
Use the built-in snipping tool to create an image from your monitor of the view's VG/ model page.
If you don't know about VG - that is probably your problem.  Ehile in the view, type VG.
Fri, Jun 21, 2013 at 10:33:32 AM | linked revit structure.rvt
clittle1230
I know how how to use the VG, I have tried all different visility options. I don't have a snipping tool in windows 8
Fri, Jun 21, 2013 at 10:41:01 AM | linked revit structure.rvt
What - They had the snipping tool in 7 and gave you nothing in 8?   Really?  Do you know how to do a simple screen capture?
You say you "..tried all different visility options..."  Then why ask questions here.
Fri, Jun 21, 2013 at 10:55:49 AM | linked revit structure.rvt
clittle1230
because I still cann't get the structure to show up in plan view
Fri, Jun 21, 2013 at 11:18:52 AM | linked revit structure.rvt
I'm saying you may NOT have done everything in VG.  You just joined so we have to assume you are new to Revit. We have been dealing with new REvit users for years and when they say "they tried everything" we know that means they tried everything THEY know.  But obvously they don't know it all.
We can't answer you if you don't give us the information we need.
Linked rvt into another rvt
Tue, Jan 20, 2009 at 12:21:13 PM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
Tagging rooms in linked RVT files
Wed, Dec 13, 2006 at 1:48:03 PM
Deleting Linked RVT Categories
Fri, Feb 3, 2006 at 9:40:29 AM
Controlling visibility in linked RVT files
Tue, Apr 18, 2006 at 1:29:10 AM
Page generation time: 3.8683
