11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Vertical and horizontal bracing connections
29 Posts No Rating |
Hi,
i am having trouble with Vertical and horizontal bracing connections in revit structures 2013. i have been working on plugin SDS/2 connect too..please see the attached file for your better understanding....
This post and image tells us that you have a problem but tells us nothing about what the problem is
Sorry.... my Bad.... please see the updated one...
Did you place your bracing using the Brace command? If so place a Reference Plan in elevation and use the Cut command then select the Brace then the Reference Plan and it will cut it to the Column.
Thanks for your reply.but i need only V/H bracing connections in SDS/2 (plugin) connect
If it is a problem with SDS you need to contact them for the information.
Vertical bracing symbolic line ??? |
Tue, Jun 4, 2013 at 7:33:50 AM
Revit 2014 Vertical Bracing Problems |
Thu, Feb 20, 2014 at 10:26:00 AM
Vertical bracing line |
Sun, Jun 2, 2013 at 2:17:03 AM
vertical bracing problem / bug |
Wed, Jan 18, 2012 at 3:13:12 AM
Horizontal Bracing - getting it to look 'right' |
Thu, Apr 1, 2010 at 5:10:01 PM
