12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Wall Alert Message
13 Posts No Rating |
Hello there!
I've been doing quite a bit of wall modelling and generally its going alright. However when I adjust the profile of some walls I get the following alert:
‘The best way to control top and base of the Wall is to modify the Constraints and Offset Parameters in Properties dialog.’
Could anyone offer any guidance to this? I use the attach top and base a lot. It appears there is a better way of doing walls but I can’t figure it from this message.
Cheers
Kinda sounds like you are combining wall attach top / bottom with the 'edit profile' tool. Not recommended. I'd use one or the other.
Edited on: Thu, Jun 20, 2013 at 12:06:57 PM
That's easy. If you take the bottom or top line of a wall and manipulate it, you will get this message. Instead, use the offset on the wall properties. The sketched adjument does not show in properties. Wall sketches should be used for other adjustments, not simple top and bottom.
Actually that is kind of easy I've just realised and quite obvous!
Thanks for your help
need help with ALERT! EGRESS PATH ON FIRE |
Fri, Dec 19, 2014 at 8:58:13 AM
Clash/interference alert question |
Fri, Oct 7, 2011 at 6:52:25 PM
Fatel Error Message |
Sat, May 13, 2006 at 5:18:41 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016 |
Tue, Oct 4, 2016 at 9:09:33 AM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
