Forums >> Revit Structure >> Technical Support >> Plotting a detail line using coordinates
Thu, Jun 20, 2013 at 11:26:53 AM | Plotting a detail line using coordinates
theeagle1972
Hi,
New to this forum so apologies if the question or a similar one has been asked previously.
We have set up a drainage arrangement for a project we are currently working on. Our current model has an architectural model linked in and our own structural model linked in.
We have been asked to plot on the drainage plan a line that will represent an existing run. We have been given a number of coordinates for the drainage run.
My question is this : is it possible to plot a detail line in a plan view using coordinates? It doesn't neccesarily need to be a drainage arrangement - this could be applicable for any number of instances.
Any help would be grately recieved.
Many thanks,
The Eagle
Thu, Jun 20, 2013 at 12:17:25 PM | Plotting a detail line using coordinates
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You should probably route the drainage runs using 'model' lines (3D / global), not detail lines which are 2d and view specific.
Or you could use 'pipes' or 'pipe placer holders' which are 3D / global.
Fri, Jun 21, 2013 at 2:46:09 AM | Plotting a detail line using coordinates
theeagle1972
thanks for the reply....using the model line facility is what I will do....what I need to know is how do you plot a model line if you have say 5 specific coordinates......i can't seem to find the command that will allow you to do this.
Cheers
Fri, Jun 21, 2013 at 7:26:50 AM | Plotting a detail line using coordinates
5 ?  Please explain that.  Do you include time and money?
Fri, Jun 21, 2013 at 11:04:27 AM | Plotting a detail line using coordinates
theeagle1972
I have 5 co-ordinates....I want to plot a model line using these co-ordinates
Fri, Jun 21, 2013 at 11:31:43 AM | Plotting a detail line using coordinates
I think you mean 5 points, each with 3 coordinates?  ???  x,y & z
We don't know how you have coordinates ... what is the base line?  If it is survey points, then that might be easier to do in your site CAD DWG if you have one.  You can also just measure off a known point for x/y.  Draw a model line then change the elevation of the ends of the line.   If the coordinates are bearing and distance, you could use a property line to get a plan view location, draw the model line with different z numbers.
Thu, Aug 10, 2017 at 4:18:47 AM | Plotting a detail line using coordinates
zakazai
Please try
http://revittoday.blogspot.ae/2009/06/insert-revit-families-using-xyz-text.html
Lines plotting half toned
Fri, Jun 15, 2012 at 10:42:01 AM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:10 PM
Plotting
Fri, Jun 19, 2009 at 4:31:47 PM
Detail Line won't change from Revision Cloud type
Sat, Dec 3, 2011 at 1:14:20 AM
Plotting Revit Projects in AutoCAD 101
Fri, Mar 26, 2010 at 7:12:17 AM
Page generation time: 3.0520
