Forums >> Revit Structure >> Technical Support >> rebar shapes
Thu, Jun 20, 2013 at 6:31:47 AM | rebar shapes
aevar
Hei
I am placing some rebars in a beam in revit structure 2013.
I have rebar hooks on each end of the rebars bu I want them to turn in different direction,  so if the rebar is in X direction i want the hook on one end to turn in Z direction and the hook in the other end in Y direction.Is this possible ???
Thu, Jun 20, 2013 at 7:28:15 AM | rebar shapes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Try to keep your questions in one spot.  This is probably the better place than your other post.
I'm assuming you are using detail components.  Just create another component in the same place and mirror it opposite of the original one.
RST Rebar Detailing
Sat, Mar 17, 2012 at 2:44:19 PM
Rebar placement in concrete pedestal not allowed
Tue, Aug 30, 2011 at 10:11:16 AM
How to apply the rebar in a ramp.
Mon, Jul 5, 2010 at 4:53:04 AM
Need help to modify rebar bar size!!!!!
Thu, Apr 6, 2017 at 3:03:05 AM
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
Page generation time: 0.0354
