Forums >> Revit Building >> Technical Support >> Revit 2013 Help.... Pick Lines tool box.
Wed, Jun 19, 2013 at 10:30:59 AM | Revit 2013 Help.... Pick Lines tool box.
coldslogan
Hi all,
I am new to revit and seem to be learning at a good pace but at the moment there is one thing that is really annoying me. When i select a wall to edit the profile in mode on the modify tab i have to click a little arrow above twice to bring up the pick lines tool.... is there a way to have the tools i need to the side without having to click this arrow because its really starting to get on my nerves..... lol.
Many Thanks,
Rob.
Wed, Jun 19, 2013 at 10:59:13 AM | Revit 2013 Help.... Pick Lines tool box.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are your Panels Maximized?
Wed, Jun 19, 2013 at 11:07:34 AM | Revit 2013 Help.... Pick Lines tool box.
coldslogan
yes i think so.... i select the wall and hit edit profile in mode, it then enters sketch mode and i have to click the arrow twice to bring up the draw menue with the tick or cross for the sketch. when i have finished editing the draw panel stays up but if i want to edit another wall profile i have to click this little arrow tab above twice to get mode back. the kicker is if i dont select edit profile now and click the arrow again i cant get draw back.... the little arrow has a drop down menue that says maximise to tabs, minimise to panel tiles and minimise to panel buttons. also cycle through all...... i have tried selecting all of these with no success..... i wish the tool bar setup was like microstation because its so much better with things like thins!!!
Thu, Jun 20, 2013 at 2:51:25 AM | Revit 2013 Help.... Pick Lines tool box.
coldslogan
Has nobody had this problem then?!? I'm desperate to find a solution here Sad
Thu, Jun 20, 2013 at 7:17:54 AM | Revit 2013 Help.... Pick Lines tool box.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is your product up to date, do you have all of the service packs installed?
Thu, Jun 20, 2013 at 11:29:23 AM | Revit 2013 Help.... Pick Lines tool box.
coldslogan
I think so yes. I have the correct tools but I can't organise what tools I want where I guess.
Thu, Jun 20, 2013 at 11:34:25 AM | Revit 2013 Help.... Pick Lines tool box.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like your screen resolution is 'squishing' the ribbon and causing the fly out effect.
Thu, Jun 20, 2013 at 1:27:26 PM | Revit 2013 Help.... Pick Lines tool box.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I think so yes"
You should really make sure.  dgcad is probably on the correct trail though.
Thu, Jun 20, 2013 at 6:37:40 PM | Revit 2013 Help.... Pick Lines tool box.
coldslogan
How do I make sure. I have all the tools help etc nothing is wrong with the program. Interestingly I do have duel screens so perhaps that might be this fly out effect. Can this. Be fixed?
Fri, Jun 21, 2013 at 7:39:53 AM | Revit 2013 Help.... Pick Lines tool box.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In your communications center you should see an area for Live Update Maintenance Patches and it should tell you if there are product updates available.  Otherwise download here http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210  there are 3 releases for 2013.
Mon, Jun 24, 2013 at 9:49:23 AM | Revit 2013 Help.... Pick Lines tool box.
#11
coldslogan
Excellent.... thanks for the help. Smile
pick walls method
Tue, Feb 19, 2013 at 4:44:03 PM
Revit 2013 into 3D Studio Design 2013
Thu, Oct 25, 2012 at 3:06:46 AM
Imported Cad Lines not "live" [ 1 2 ]
Fri, Aug 15, 2008 at 2:02:40 PM
15
Revit Architecture 2013 - Decal Tool not functioning
Mon, Jan 13, 2014 at 10:18:31 PM
My 2013 revit Student verion has problem
Sun, Nov 2, 2014 at 6:00:38 PM
Page generation time: 2.2957
