30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Revit Architecture 2013 - Decal Tool not functioning
1 Posts No Rating |
Everytime I click on the "Decal" Tool, the ribbon changes for less than a second to the "Modify | Decal" dialogue and then goes back to normal (no active tools). This is apparently only a problem in the model I'm working with as I was able to use the decal tool in a basic, new project. I've tried the following:
- Clicking on the decal tool while in different types of views (3D, plan, elevation, etc.)
- Deleting all decal types and adding new ones
- Using the decal on other's computers who are working on the same project
- Setting my work plane before clicking on the decal tool
- Restarting Revit
- Auditing the file
Has anyone ever had this issue or does anyone have any potential solutions? Thanks!
Do you have all of the updates installed? << Always the first place to check on something like this.
0 Posts No Rating |
I'm having the same issue in Revit 2013 - and yes, my software is up to date. The decals were working last year, so maybe one of the softeware updates is the problem.
0 Posts No Rating |
Check the File location, and file type and size as well. I recomend you not to use files much larger than 100Kb.
Try to use Jpg, Bmp and Png format files
0 Posts No Rating |
Thanks for the advice, however, the file locations are correct and the average file size is 50kB. Also the decals used to work in this project - I just wanted to re-apply a couple of them.
Further investigation indicates the problem is project specific as my "place decal" command works in other projects, so maybe an error or a bug in this particular project.
Revit Architecture 2009 Decal tools |
Fri, Jul 25, 2008 at 8:34:10 AM
Decal borders in 2013 |
Thu, Sep 5, 2013 at 2:11:23 PM
Decal Changing Sizes in Rendering |
Thu, Jul 25, 2013 at 1:56:16 PM
using The Decal tool help |
Sat, Mar 4, 2006 at 1:53:06 PM
Using tools in the Systems tab - Revit Architecture 2013 |
Wed, Sep 19, 2012 at 4:21:08 PM
