28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Topografy Hatch disapear under Pad
31 Posts No Rating |
Hi, I've searched other forums with no success.
I have 2 pads - one under the basement floor and one partly under the first floor. (Please see image)
When I am at the basement floorplan the hatch under the upper pad disapear.
In the V/G everything is turned on and I have not hidden anything.
My Cut plane is at 1.8m, the Top is at 2.30m, the Bottom 0.00.
What could be the problem?
try to change top offset of view range lower at the view.
families show up at a plan view if they-pads in this case- are inside of view range.
want more?
You can get more tips at Enjoy Revit |
Tried it with no success, thank you for the sugestion anyway.
I remade the topography from skratch and the problem was fixed.
Topo hatch disappear under building pad |
Mon, Jan 27, 2014 at 8:27:53 AM
Revit Topography Cut Hatch only shows up under Building Pad |
Fri, Feb 24, 2017 at 11:31:36 AM
Building Pad Problem |
Thu, Dec 20, 2012 at 3:51:08 PM
Section cut_ wall sweep causes materials to disapear |
Tue, Feb 2, 2016 at 12:44:28 PM
Topo Hatch not showing up under building pad - 2013 |
Thu, Aug 13, 2020 at 5:47:10 AM
14
