Forums >> Revit Building >> Technical Support >> whole project: walls, floors and roofs for laser cutting and building a physical
Mon, Jun 17, 2013 at 10:29:37 PM | whole project: walls, floors and roofs for laser cutting and building a physical
mj8rybin
Revit is great except the step where I try to convert or export the whole project into laser drawings, in order build a physical model. Obviously there are many floors, walls and roofs or planes; each requiring its own flat drawing or dxf file for laser cutting. Every time I have had to completely redraw the project in another program. I did some research but found no solution. Any suggestions?
Tue, Jun 18, 2013 at 7:43:15 AM | whole project: walls, floors and roofs for laser cutting and building a physical
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Im not sure what the problem is. You can export whatever view you want to a .DXF file.  Did you look in your HELP?
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171/2172-Export2172/2173-Exportin2173/2175-Exportin2175
building a physical model from a revit file
Wed, May 9, 2007 at 9:31:57 PM
How do you convert massings into floors, walls and roofs??
Thu, Jul 16, 2009 at 4:48:55 PM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Problem: Gutters / Cutting Walls and Roofs (not footprint)
Thu, Jul 18, 2013 at 7:07:41 AM
Single Line - Laser Cut Export
Sun, Jul 17, 2016 at 4:42:57 PM
Page generation time: 4.5945
