11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 Imaginit Renumber
Hello
Floorplan Room Space Tags.
I have run the imaginit renumber several times. The propose sequence to rooms populates the current room number but does not update the room tag. I place another tag to reference and it does not reflect the renumber. Any ideas????
Something is wrong here because what you say just can't happen. Maybe your tag reads a different variable. Mayme you have multiple rooms. You will have to give us more information.
I suggest you do a room schedule and show all instances.
Thanks wwhub. We have mulpitple room area plans (views) for this project to show different area calculations. I wonder if this is affecting the tag. I have checked for multiple spaces. If I delete the current room tag and replace it...the space still reads the previous number and not the new sequence within IMAGINit.
Will have to delve deeper. Very frustrating
Area plans and room areas are two different processes. You should keep these seperate.
Tags are just annotative elements. Rooms are what you shold be deleting to see if you have multiple rooms in the same place.
I checked the Room tag and the parameter was set to department not room number. Cheers
Element ReNumber and Sheet Order Apps |
Wed, Sep 23, 2009 at 5:54:20 PM
Sheets renumber |
Fri, Feb 3, 2006 at 6:10:10 PM
deleating doors from project and tagging problems |
Fri, Jan 4, 2013 at 1:36:42 PM
Window & door tag formatting |
Tue, May 30, 2006 at 12:23:29 AM
auto view renumbering |
Thu, Oct 30, 2014 at 3:06:34 PM
