Forums >> Revit Building >> Technical Support >> Convert Surface to Joined solid geometry
Fri, Jun 14, 2013 at 3:18:24 PM | Convert Surface to Joined solid geometry
Yolandaaaaa
How do you convert a surface to a joined solid geometry? I know you can't cut into a surface and it must be converted into a soilid. I did that somehow and created a void in it but I have no idea how I did that.
Please use lament terms because this is my first time playing with conceputal masses haha
I am using Revit 2013
Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 3:18:43 PM
Material surface pattern on a solid sweep?
Wed, Nov 17, 2010 at 2:48:49 PM
convert CAD file to PAT file for surface patterns in Revit
Mon, Aug 25, 2008 at 1:50:30 PM
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:15:59 AM
Exporting surface Geometry from Revit (2011 and above)
Tue, Nov 13, 2012 at 8:14:04 AM
Page generation time: 2.1303
