Forums >> Revit Building >> Technical Support >> Rotating property line and site without moving building...
Fri, Jun 14, 2013 at 3:08:53 PM | Rotating property line and site without moving building...
1bobingram
How do I rotate a site and topography to a plane without moving the building on that property?
Thanks!
Fri, Jun 14, 2013 at 4:14:17 PM | Rotating property line and site without moving building...
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Select everything you want to rotate, topo, property lines, trees etc then use the rotate command. Use visibility graphics or filters to finite your selection.
Just don't pick the building. There's also going to be some cleanup. Probably a good idea to use some reference planes to make the rotation point.
Sat, Jun 15, 2013 at 1:23:43 AM | Rotating property line and site without moving building...
1bobingram
Well you weren't lying about the "clean up work". My plants and downspouts decided to elevate/offset themselves randomly, but 1000 thank you's.  I can't imagin the amout of work you saved me.  I think that I've discovered that in the future I should have my site in one project and my structure on another and then link them.  this would have made the process simple.  Do you concur?
Live and learn I guess.
Thanks again!
Sat, Jun 15, 2013 at 10:31:20 AM | Rotating property line and site without moving building...
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes, seperate the site from the building and link.
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:55 AM
Dimensioning a building on the site
Mon, Mar 7, 2011 at 12:12:05 PM
Property line
Tue, Oct 13, 2009 at 5:31:57 PM
Moving Building up with out moving the site
Sun, Jul 31, 2016 at 5:20:10 PM
Rotating/Moving a building
Tue, Jan 20, 2015 at 10:28:55 AM
Page generation time: 0.8240
