Forums >> Revit Building >> Technical Support >> 3d mesh
Tue, Feb 7, 2006 at 5:31:30 PM | 3d mesh
hippy
Now they want a corinthian column. Can anyone tell me where to find a tutorial on creating 3d mesh in autocad? Or any other way to build this one?
Tue, Feb 7, 2006 at 5:38:15 PM | RE: 3d mesh
eldados
eldados Avatar
4.5 Stars: 8 Votes
mmm... it can be a pain to start from scratch. have you tried the 3D sites around? like 3dcafe.com...
Integrator
KarelCAD
Sun, Feb 12, 2006 at 10:06:22 AM | RE: 3d mesh
hippy
Found some good stuff there, but can't figure out how to get max models into revit. Is this where rpc comes in?
Sun, Feb 12, 2006 at 5:49:38 PM | RE: 3d mesh
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You'll need to convert the Max model to dwg first.
Tue, Feb 14, 2006 at 12:16:26 PM | RE: 3d mesh
hippy
My ignorance is showing through. The model is .3ds 3D studio guessing that is different from 3d max but either way I have no hint how to make it a .dwg. Any hints? Post edited on 2006-02-14 12:18:08
Tue, Feb 14, 2006 at 4:35:42 PM | RE: 3d mesh
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can convert a 3ds file to a dwg using programs such as viz, max, rhino, hexagon (has a free trial) and i'm pretty sure there is a free 3D package available that has this ability... Will need to check up on the name.
Tue, Feb 14, 2006 at 5:41:52 PM | RE: 3d mesh
eldados
eldados Avatar
4.5 Stars: 8 Votes
just open your 3ds file (which is a max file) and save as or export to dwg.
Integrator
KarelCAD
Thu, Feb 16, 2006 at 9:01:11 AM | RE: 3d mesh
tomnewsom
Autocad will import your .3ds file, you can then save it as a dwg. (might be an idea to do some cleaning up, moving things to 0,0, all to layer 0 etc)
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 7:42:42 PM
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Mesh not rendering to scale???
Mon, Feb 15, 2010 at 12:43:01 PM
Page generation time: 0.1317
