Forums >> Revit Building >> Technical Support >> Door and frame Schedele
Fri, Jun 14, 2013 at 11:11:42 AM | Door and frame Schedele
franchevich
Does any one knows how to remove thes doors?
When  I delete them, revit keep replacing them,
Thanks,
Fri, Jun 14, 2013 at 11:14:33 AM | Door and frame Schedele
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"revit keep replacing them"
Are you sure you are deleting the corect door?  Revit doesn't just add doors. Are you working on a workshared project?
Fri, Jun 14, 2013 at 11:48:10 AM | Door and frame Schedele
franchevich
Yes,
These doors they don't exist in the project
Fri, Jun 14, 2013 at 11:54:38 AM | Door and frame Schedele
They may be doors within other doors or other families.  If a door family is created and it has a nested family within it that is also a door family and that nested family is set to shared, then the nested family will show up in your schedule.
Add another parameter in your schedule - family name - and see what you have.
Fri, Jun 14, 2013 at 1:39:13 PM | Door and frame Schedele
franchevich
Nice tip, I'll add the family name parameter,
thx
Fri, Jun 14, 2013 at 1:41:59 PM | Door and frame Schedele
franchevich
yes it looks like there is another family nested right? see attachement
Fri, Jun 14, 2013 at 1:44:08 PM | Door and frame Schedele
franchevich
I need to remove this F type door now, any tips?
Fri, Jun 14, 2013 at 2:15:46 PM | Door and frame Schedele
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you filter by Family F
Fri, Jun 14, 2013 at 2:17:13 PM | Door and frame Schedele
Pick one in the schedule and and pick "show".  That should show you what family it is nested in.
Edited on: Fri, Jun 14, 2013 at 2:17:54 PM
Fri, Jun 14, 2013 at 2:56:31 PM | Door and frame Schedele
franchevich
The bugging door is a nested door panel called out as a door,  Sad
Mon, Jul 8, 2013 at 3:58:36 PM | Door and frame Schedele
franchevich
The solution for this issue it was to remove the nested door panel from door family,
Thanks,
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
door frame off-set
Wed, Mar 11, 2015 at 7:42:20 AM
Door Frame
Tue, Sep 28, 2004 at 5:58:51 PM
Best practice for scheduling door frame types when the frame is a curtain wall
Mon, Mar 23, 2015 at 10:49:57 AM
Door & HM frame w/ 4" head
Fri, Dec 21, 2007 at 7:05:40 AM
Page generation time: 0.1706
