Forums >> Revit Structure >> Technical Support >> WT column - help?
Thu, Jun 13, 2013 at 2:42:25 PM | WT column - help?
sblake
I need a WT column in my project. Not a beam, but a column. When I go to load a column, a WT is not an option. Advice?
Revit Structure 2012
Thu, Jun 13, 2013 at 10:41:54 PM | WT column - help?
CDWdavid
5 Stars: 5 Votes
Hi Sblake,
In Project Brower, go to "Familis", scroll down to "Structural Columns", not "Columns" which mainly are architectural columns, then you will see "W-Wide Flange-Column" family.
If it is not in your project families, go to "Open", click "Imperial Library", scroll down to "Structural Cplumns" not "Columns", under "Steel" folder, you will see "W-Wide Flange-Column".
Fri, Jun 14, 2013 at 8:29:35 AM | WT column - help?
sblake
I was looking for a WT family, not a W family. I found them on an AUGI board.
Fri, Jun 14, 2013 at 9:10:49 AM | WT column - help?
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28837
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
L shaped column
Mon, Jun 22, 2015 at 4:37:29 AM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:43 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Page generation time: 0.9276
