Forums >> Revit Building >> Technical Support >> revit 2013 exterior walls not showing correct
Wed, Jun 12, 2013 at 1:43:36 PM | revit 2013 exterior walls not showing correct
Nashid360
I have inserted a vinyl siding profile on my exterior walls, but it only shows them 3d when i select the wall. How do I get the wall to show up with the 3d vinyl siding?  also when I apply paint on the walls it only coats the interior side. How do I paint the exterior side?
Wed, Jun 12, 2013 at 2:03:58 PM | revit 2013 exterior walls not showing correct
Paint from an outside view - paint can be applied to any surface but you have to pick it.
I don't know what your image is - please describe better what you are doing.  That is not a simple material.
Wed, Jun 12, 2013 at 2:34:03 PM | revit 2013 exterior walls not showing correct
Nashid360
I am trying to create a 3d vinyl siding. Ive already created the wall structure, and when I click on a vinyl wall in the 3d view it shows correct.  However when I deselect the wall, the 3d sidding goes away back to 2d.  how do you get the 3d siding to be vissible in all views at all times?
Wed, Jun 12, 2013 at 2:49:58 PM | revit 2013 exterior walls not showing correct
As I said before - This is not a simple material - correct?  So how did you make this?
Wed, Jun 12, 2013 at 3:02:54 PM | revit 2013 exterior walls not showing correct
Nashid360
ive already created the vinyl wall structure by using reveals. under the wall type properties>structure> reveals> add profile. i had to add the profile several times to create a wall of vinyl siding. after adding the profiles the vinyl wall was created.
Wed, Jun 12, 2013 at 3:18:52 PM | revit 2013 exterior walls not showing correct
Obvoiuly something is flawed in your process.  Attached is mine done in a similar fashion Revit 13.  Maybe you have two walls in the same place.
I must caution you.  On small projects, this may work but in most cases, this will overwhelm your model and a material is a better process.
Wed, Jun 12, 2013 at 3:46:08 PM | revit 2013 exterior walls not showing correct
Nashid360
I made it to that point. No double walls. thanks for your effort
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ]
Wed, Sep 23, 2015 at 2:57:56 AM
19
Spaces don't recognize exterior walls
Fri, Feb 3, 2012 at 9:49:40 AM
New Construction Wall showing up Black on exterior
Tue, Jan 24, 2012 at 3:50:50 PM
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
Thu, Jul 7, 2016 at 10:50:48 AM
Revit Architecture 2013 - Cannot dimension endpoints of walls/corners. HELP!
Thu, Jul 18, 2013 at 8:24:17 PM
Page generation time: 3.0312
