Forums >> Revit Building >> Technical Support >> interior elevations tag question
Wed, Jun 12, 2013 at 1:27:15 PM | interior elevations tag question
sgray05
Is there a way to disassocate the name provided in the Project Borwser with what is shown on the interior elevation tag in plan view?
Whatever name I give in the project browser is also showing up on the tag. I am looking to just provide a numbe r(or letter) for the differenent elevations within the same room.
An additional, somewhat related note. Is there a way to all four elevations be reference to the same detail number on the sheets and only be defined by a letter.
For instance, single use bathroom. interior elevation is reference to 1/A6.0 with the north elevation being identified as A; east as B; ect..
rather than the north being detail 1, east being detail 2....
Wed, Jun 12, 2013 at 1:49:42 PM | interior elevations tag question
sgray05
After some digging I discovered the answer to first part of my question. It is located under Edit Type while having the tag selected. THen you can change the elevation tag type.
Second part of my question is still an unknown.
Wed, Jun 12, 2013 at 2:00:54 PM | interior elevations tag question
Your question is not clear.  Obviously, elevation A (or 1) is a different view from B (or 2).  The reference can be number or letter.... change it!
So the result will be A/A6.0, B/A6.0, C/A6.0 .......
interior elevations
Wed, Apr 11, 2007 at 9:43:04 AM
Adding a Tail to Interior Elevation Tag
Fri, Mar 14, 2014 at 1:10:11 PM
updating material tag on interior elevations
Wed, Mar 27, 2013 at 7:05:30 AM
rotating interior elevations
Fri, Mar 17, 2017 at 6:52:25 AM
View titles lettered for interior elevations, cannot duplicate...
Wed, May 31, 2017 at 10:43:39 AM
Page generation time: 2.0967
