Forums >> Revit Structure >> Technical Support >> Cursor not visible in schedules, Revit Structure 2014
Wed, Jun 12, 2013 at 11:41:25 AM | Cursor not visible in schedules, Revit Structure 2014
allstardrafter
After recently installing Revit Structure 2014, I noticed that when I'm editing my text fields inside of a schedule, my cursor isn't showing up. When I click into a text string within the schedule, my cursor will be placed where I have clicked, but then it disappears. So if I look away and then look back, I have no idea where cursor is. Or worse yet, if I try to use the arrow keys to navigate my way around in a piece of text, then I really don't have any idea where my cursor is.
This has made editing my schedules very difficult. Has anyone else had this same issue?
Wed, Jun 12, 2013 at 12:01:16 PM | Cursor not visible in schedules, Revit Structure 2014
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I've had the same problem. I thinks it's a software issue.
Wed, Jun 12, 2013 at 12:52:04 PM | Cursor not visible in schedules, Revit Structure 2014
allstardrafter
Did you find a fix for it? I was figuring it could be a software issue, but not sure where to start because I don't have this issue when using Revit 2013. Anyone know of any system requirement changes between Revit 2013 & 2014?
Edited on: Wed, Jun 12, 2013 at 1:11:02 PM
Wed, Jun 12, 2013 at 1:05:17 PM | Cursor not visible in schedules, Revit Structure 2014
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No solution so far . . . .  .A REVIT service pack.
Probably a glitch between Autodesk and Microsoft with regards to specific drivers.
Tue, Apr 29, 2014 at 2:01:04 PM | Cursor not visible in schedules, Revit Structure 2014
allstardrafter
Has anyone had any updates on this issue, or solutions? I just downloaded Revit Structure 2015 and I'm still have the same issue with it!
Tue, Apr 29, 2014 at 2:16:15 PM | Cursor not visible in schedules, Revit Structure 2014
Could this have been fixed with update 1?  You did search for and install updates - right?
Revit Structure 2014 - Jerky / Slow - why?
Wed, Mar 11, 2015 at 9:44:24 AM
Revit Structure Lt or Full Version?
Tue, Sep 10, 2013 at 8:25:18 AM
Revit 2014 schedules... where did the Show button go?
Mon, Dec 16, 2013 at 2:18:43 PM
Deleted objects still visible on other levels
Tue, Aug 2, 2011 at 10:04:59 AM
Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Thu, Mar 30, 2017 at 1:15:02 PM
Page generation time: 1.3825
