Forums >> Revit Building >> Technical Support >> Linked Door Schedule
Wed, Jun 12, 2013 at 11:02:16 AM | Linked Door Schedule
jsel13
I'm linking a door schedule into another file and in my mian model, i have a parameter called "From Room: Name" which says which room the door is from. i dont know where this came from because i dont see it under the properties of the door.
in anycase, it shows up in my schedule on the main model. but when i link the model into my other file, and do the door schedule, that parametr doesnt show up and i dont know how to add it into my new file because it doesnt show up under the project parameter list in either file. any ideas?
Wed, Jun 12, 2013 at 11:11:46 AM | Linked Door Schedule
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The From Room To Room properties show up on the lower left of the fields tab of the schedule dialog box.
See image.
Wed, Jun 12, 2013 at 11:30:16 AM | Linked Door Schedule
jsel13
thanks for the help, but the problem is that its not finding the rooms from the linked model
Wed, Jun 12, 2013 at 11:56:10 AM | Linked Door Schedule
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Check off the option to 'Include Elements in Linked Files'.
Wed, Jun 12, 2013 at 1:01:36 PM | Linked Door Schedule
jsel13
i have it checked off, thats how im able to populate the schedule, the only problem is that the rooms arent coming in and i have no clue why.   see attached pdf. all the info in this schedule is being pulled form a linked model
Mon, Jan 20, 2014 at 1:38:50 PM | Linked Door Schedule
TBOSA
Has a solution been found for this? I'm having this same problem with my door schedule. We have rooms in one model and doors in another model with the schedule in the third model (that both are linked to). The room names and numbers do not show up.
Using 2013 with 'Include elements in linked files' checked.
Mon, Jan 20, 2014 at 2:19:22 PM | Linked Door Schedule
Why so convoluted?
I have always believed that in order for Revit to associate one thing with another, that they both had to be in the same model.  So to place a door in a wall, they both have to be in the same model.  For a door to associate with a room, I think they both must be in the same model as well.
Mon, Jan 20, 2014 at 2:47:02 PM | Linked Door Schedule
TBOSA
Nothing convoluted about it...
We have a large new building attached to several other existing large buildings (some of which have new work in them). These doors are exterior doors and are in the shell model. The rooms are in the interiors model. The schedule & sheets are in the central model. Otherwise, our files would be so large that we wouldn't be able to open them.
Mon, Jan 20, 2014 at 2:48:49 PM | Linked Door Schedule
TBOSA
One correction: The Rooms are in the central model, not the interiors model.
Edited on: Mon, Jan 20, 2014 at 3:03:26 PM
Edited on: Mon, Jan 20, 2014 at 3:58:54 PM
Door schedule with linked models - multiple models but door mark is the same
Wed, Apr 22, 2026 at 3:01:42 PM
Door schedule parameters not displaying "room names" from linked revit model.
Fri, May 15, 2015 at 1:22:11 PM
Linked Door Schedule Problems
Fri, Jul 4, 2008 at 3:37:38 AM
Door Schdule
Tue, Jul 9, 2013 at 3:23:33 AM
Page generation time: 1.5137
