20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Wall Joins on Short Walls
21 Posts No Rating |
Hi, I'm working with 2013 and am curious to know how to have my walls clean up when there is only a slight shift (8") in the wall? I'm currently showing a third wall (highlighted in blue) that creates the jog, but as 4 walls are coming together, no amount of join conditioning or grip-pulling seems to resolve the issue. I am curious to know if it has something to do with the wall make-up which is why I've attached a few screen shots of the walls in question. Any thoughts/guidance/help is of course appreciated!
Short returns are always a problem.
I would try turning off the wall join for the wall on the right. (Blue grip button for that wall - turn off join)
That's a pretty busy intersection with some short wall segments. I wouldn't get my hopes up on organically having REVIT clean this up without a little tweaking, 'edit cut profile', masking and disallowing joins, also 'corner joins' butt vs miter.
Sloped walls joins problem |
Sat, Oct 16, 2010 at 6:17:23 PM
Can you make wall joins Miter by Default? |
Wed, Dec 21, 2016 at 1:52:44 PM
14
I hate the Revit Automatic Wall joins |
Thu, Oct 25, 2007 at 9:59:44 AM
short walls+phases problematic |
Fri, Dec 16, 2005 at 7:15:16 PM
Stacked walls and regular walls won't clean joins |
Mon, May 23, 2005 at 8:42:41 PM
