Forums >> Revit Building >> Technical Support >> Revit 2012 Sheets & Model Space / Paper space in CAD
Wed, Jun 12, 2013 at 3:08:15 AM | Revit 2012 Sheets & Model Space / Paper space in CAD
bjwson
2.5 Stars: 3 Votes
Hi All,
This is a classic one.
Client wants same file name, but they are split into 3 sheets... like 1 of 3, 2 of 3 & 3 of 3.....therefore he says have 3 tabs in CAD.....now the question is, im doing all my work in Revit 2012 &  want to export later into Autocad...how can i do this.
Any tips. Need Help.
thx.
W
Wed, Jun 12, 2013 at 3:44:16 AM | Revit 2012 Sheets & Model Space / Paper space in CAD
4 Stars: 205 Votes
Here: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171/2172-Export2172/2173-Exportin2173
Wed, Jun 12, 2013 at 4:36:22 AM | Revit 2012 Sheets & Model Space / Paper space in CAD
bjwson
2.5 Stars: 3 Votes
Hi, Pls. read my Question again. no answer found in the link below.
Simply, When i export Revit to CAD is there a way of getting 3 Tabs in Autocad instead of three files with different names, my requirement is 3 Tabs in Autocad. so that the file name can remain same for 3 sheets,
thx.
W
Wed, Jun 12, 2013 at 6:36:59 AM | Revit 2012 Sheets & Model Space / Paper space in CAD
As far as I know, there is no way to do this from Revit.  Instead, export both sheets with x-refed views, then in CAD, create the second sheet and tie in the appropriate x-refed views.
Importing Paper Space/Model Space from CAD File
Mon, Nov 17, 2014 at 9:46:02 AM
Importing .dwg Details - Model Space vs. Paper Space
Wed, Aug 9, 2006 at 5:37:45 PM
DWG sheets to RVT
Sun, Jun 9, 2019 at 10:57:52 PM
Exporting Revit 2009 Sheets to CAD
Wed, Jun 18, 2008 at 3:53:01 PM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Page generation time: 2.6251
