Forums >> General Discussion >> Revit Project Management >> Roof over ramps - Roofing with a variable work plane
Tue, Jun 11, 2013 at 7:44:44 PM | Roof over ramps - Roofing with a variable work plane
Spletz
Hi,I have a ramp that is an ADA accessible ramp complete with flat landings. I'd like to make a simple gable roof that follows this ramp and maintains a constant ridge height from the ramp in section. IE wherever I cut the ramp in section, the roof looks the same. I thought an in place sweep of type roof would be the way to go, but it seems you can't select the edges of ramps. Anybody ever try this? Is there a way to make a simple gable and rotate it in elevation or something? Seems such a simple idea and very basic type of construction, but very difficult to figure out how to model it in Revit. I'm using Revit 2013.Thanks.-eric
Tue, Jun 11, 2013 at 8:30:28 PM | Roof over ramps - Roofing with a variable work plane
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Create a reference planeat the same angle as the ramp offset to the height you need and create an in place extrusion. Or a sweep if you need it to slope and go flat at the landings
Wed, Jun 19, 2013 at 2:49:06 PM | Roof over ramps - Roofing with a variable work plane
Spletz
That would be fine and good, but it's of course and ADA ramp with many flat areas, so short of creating a different roof for each stretch, that won't work either.  Seems like a real shortcoming in the roofs tool.
Wed, Jun 19, 2013 at 3:20:23 PM | Roof over ramps - Roofing with a variable work plane
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Seems like a real shortcoming in the roofs tool"
This isn't exactly a conventional roof so I don't really find it a shortcoming.  You can easily create a model in-place component under the roof category to achieve what you need
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
Roof with variable thickness on sloping framing
Wed, Jan 20, 2010 at 10:12:06 AM
how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
Fri, Apr 24, 2015 at 4:08:14 PM
Roofing Material Look alike
Wed, Nov 21, 2012 at 5:35:57 PM
Creating Realistic Texture For Roof
Tue, Feb 26, 2019 at 1:37:49 PM
Page generation time: 0.6540
