Forums >> Revit Building >> Technical Support >> Revit 2013 making walls by faces and some walls are very strange... please help!
Mon, Jun 10, 2013 at 11:35:03 PM | Revit 2013 making walls by faces and some walls are very strange... please help!
jabuchenauer
Ok, see if any of you revit gurus can figure this one out.  I imported my rhino file with all of my walls, roofs, and curtain systems set up as surfaces in a conceptual mass, with the intention of using the revi building maker to convert them to the various components.  Just started doing the walls, and all seemed to be fine, except suddenly, my walls weren't joining!  Well, except for ONE of them, which seems to somehow be hosted to a reference plane, even though i made all the walls with the wall by face tool.  i've attached a screenshot, and look not only at the wall properties, but also the difference in the selection.
Also, if someone has a better way of making ribs and such, whether it be in revit or rhino, could someone give me some tips on the best ways to go about that?
Edited on: Mon, Jun 10, 2013 at 11:56:42 PM
Tue, Jun 11, 2013 at 7:30:28 AM | Revit 2013 making walls by faces and some walls are very strange... please help!
Wall by face exactly mimics the mass.  Normal wall tools are not available in this category.
Wed, Jun 19, 2013 at 12:13:12 AM | Revit 2013 making walls by faces and some walls are very strange... please help!
jabuchenauer
Hmm, I'm not sure if this actually answers what I'm asking.  Can you take another look?
Wed, Jun 19, 2013 at 7:05:58 AM | Revit 2013 making walls by faces and some walls are very strange... please help!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What answer are you looking for?  Your images don't tell me anything, I don't see any walls that aren't joining or which one is hosted to a reference plan (if you used wall by face then its on the face of the mass).
Picking multiple faces when creating walls
Fri, May 6, 2011 at 2:12:40 PM
Revit Architecture 2013 - Cannot dimension endpoints of walls/corners. HELP!
Thu, Jul 18, 2013 at 8:24:17 PM
Can't select Wall and Grid - Not Design Option fault
Thu, Jun 20, 2013 at 10:30:13 AM
Making in place walls look like walls in plan
Tue, Aug 9, 2005 at 9:11:59 PM
Walls/doors behaving VERY strange in v.2010 - PLEASE HELP
Wed, Sep 30, 2009 at 8:10:53 AM
Page generation time: 3.3116
