Forums >> Revit Building >> Technical Support >> Floor - line artifacts in PDF
Mon, Jun 10, 2013 at 6:12:36 PM | Floor - line artifacts in PDF
mezdez24
4.5 Stars: 3 Votes
I have a floor plate that produces strange lines when I "print to pdf". It only happens when I use the ellipse tool in sketch mode. The floor is completely flat. I've also tried turning off all Any ideas on why this happens? I'm using Revit ARch 2012.
thanks in advance!
Tue, Jun 11, 2013 at 7:27:28 AM | Floor - line artifacts in PDF
I believe that is a material problem.  Change it to one without a pattern and see what happens.
Tue, Jun 11, 2013 at 2:02:30 PM | Floor - line artifacts in PDF
mezdez24
4.5 Stars: 3 Votes
thank you for the tip. I did try selecting the floor and changing the floor type to a generic with no pattern. It still shows the lines. I believe it has to do with the ellipse or the program/software translation of Bluebeam or Adobe PDF when I print. I had to re-draw the eliipse as a series of lines.
Tue, Jun 11, 2013 at 2:14:04 PM | Floor - line artifacts in PDF
I don't ever use true ellipses, they are too hard to define and not necessary.  Before CAD and drafting templates, we always constructed ellipses using just 2 arc radii, 4 arcs total.  Those you can define so that the contractor can build them.
http://etc.usf.edu/clipart/76200/76201/76201_ellps_4cntr.htm
This link shows how close an appromation is to a real ellipse - note that very long, thin ellipses do not work as well.
 http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM
Shadow Artifacts in Elevation
Wed, Aug 19, 2009 at 8:59:26 AM
Truss are rendering with many artifacts.
Mon, Feb 17, 2025 at 6:44:42 PM
problem printing line weight to pdf
Tue, Sep 30, 2014 at 3:31:49 PM
Pdf with no lineweights
Tue, Oct 28, 2008 at 11:30:16 PM
Section through floor graphic shows dashed lines
Wed, Oct 26, 2016 at 9:41:56 AM
Page generation time: 0.5701
