Forums >> Revit Building >> Technical Support >> Revit2013 - 'Pipe Size' Parameter Can't Be Used
Mon, Jun 10, 2013 at 11:47:36 AM | Revit2013 - 'Pipe Size' Parameter Can't Be Used
TerribleTim
Hey gang, I posted this over on AUGI but was hopign someone here might be smarter and/or quicker. I've got a family that I need to add a "cold water connection size" parameter to but am having a problem. We have all of these parameters in a file, so it's just a simple issue of adding the right one. But when I choose any "Pipe Size" parameter I get a message of "Parameter Type 'Pipe Size' Cannot Be Used". Any idea what is going on here?
Mon, Jun 10, 2013 at 12:16:49 PM | Revit2013 - 'Pipe Size' Parameter Can't Be Used
What category is the family?  Where does it sort out in your browser?
Mon, Jun 10, 2013 at 1:01:43 PM | Revit2013 - 'Pipe Size' Parameter Can't Be Used
TerribleTim
It is a Specialty Equipment category family. Like I said, we have these parameters pre-edited and held in a file for quick loading, and we've loaded this same parameter to other families of the same category type without issue.
Mon, Jun 10, 2013 at 2:25:34 PM | Revit2013 - 'Pipe Size' Parameter Can't Be Used
I don't do MEP but if that is a system parameter, it may not be usable in that family category.
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Changing paramaters of 'Title with line'
Wed, Sep 20, 2006 at 9:47:18 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
I can't change the connecor size. It stays on -609.6 mm
Mon, May 18, 2015 at 7:06:40 AM
Page generation time: 0.7421
