Forums >> Revit Building >> Technical Support >> Walls not attaching to the correct level
Fri, Jun 7, 2013 at 2:49:47 PM | Walls not attaching to the correct level
eridenour
REVIT 2014 - Architecture
I am having problems with my walls listing one thing in the properties box regarding their top constraint but doing another. And of course its not all walls giving me this problem. Attached is a pdf of the screen shots of the two walls - including the properties box dialogue. - Any help is appreciated. Thank you
Building has 5 levels, in order from bottom to top: Sub Level 2, Sub-level 1, Ground floor, Terrace, & Parapet
Wall type A (two walls stacked) is similar to Wall type B (has 3 walls stacked)
Wall A: According to the Properties manager: Bottom Constraint = Ground Floor; top Constraint = Parapet level -11" offset
Wall B: According to the Properties manager: Bottom Constraint = Sublevel 2; top Constraint = Parapet level -11" offset
I have checked this multple times and compared the two walls and the setttings are the same. However Wall type A is attaching the top to the Terrace instead of the Parapet.
I am having this same problem with some of the interior walls that I want to have an unconnected height of 36". The properties reads Unconnect wall height 3'-0" the top constraint is set to none, but then the walls in the model reach the terrace level - Is there a setting on the Terrace level that could be causing this issue?
Mon, Jun 10, 2013 at 6:25:49 AM | Walls not attaching to the correct level
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Looks like the walls are attached. Select the wall and click on 'Detach' from the modify tab.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Mon, Jun 10, 2013 at 8:10:59 AM | Walls not attaching to the correct level
eridenour
Thank you - that worked.
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
Grouping Walls and attaching them to Floors
Mon, Feb 15, 2010 at 4:10:51 PM
Structural Trusses not attaching to walls
Fri, Dec 14, 2007 at 10:54:26 AM
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Page generation time: 1.3830
