Forums >> Revit Structure >> Technical Support >> Hiding specific dimensions
Fri, Jun 7, 2013 at 1:32:13 PM | Hiding specific dimensions
MarcelloD
Hi, I'm new to the website, and I thought you guys might be able to help me with a small problem I have.The situation is I've got a project that requires diferent types of dimensions, for diferent approval phases. For example, dimensions that count the finish of the walls must be shown in one phase, whereas in the calculation phase only the dimensions between structural axes can be shown. However, I can't just delete either of them since I might need them again later.So my question is, is there a way to automatically hide only certain types of dimensions? Or any way to automatically make existing dimensions infer to wall centerline intead of wall faces?Thanks in advance, and great site!
Mon, Jun 10, 2013 at 7:20:50 AM | Hiding specific dimensions
Why not just set up multiple views?
Create a new view and copy/paste same place everything you need.  (Hint - window the sheet and use the filter for just the annotative elements. - 2-3 minute process.)
How Can I Change The Dimensions Of A Window To A Specific Custom Size?
Tue, May 26, 2009 at 7:28:02 AM
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
Crop hiding dimensions
Mon, Jul 9, 2007 at 3:32:51 PM
13
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Mon, Jul 9, 2007 at 7:09:32 PM
Page generation time: 0.9816
