Forums >> Revit Building >> Technical Support >> Additional Roof will not attach to original roof
Fri, Jun 7, 2013 at 7:29:59 AM | Additional Roof will not attach to original roof
fgibase4
4 Stars: 1 Votes
Hi guys. I'm having an issue connecting the roof of an addition to a dentist office with the roof of the as-built structure. I keep getting an error message that says "part of the roof to be joined misses the target face", when using the roof join command. This command has worked for several other roofs on the structure , but not this one. Any help would be greatly appreciated.
I attached an image of the problem. The highlighted roof needs to attach to larger existing roof (just ignore the unconnected walls at the moment).
Thanks a bunch!
Fri, Jun 7, 2013 at 7:38:36 AM | Additional Roof will not attach to original roof
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How is that hip roof (in blue) suppose to attach to the main gable roof?  It doesn't look like the slopes will match up correctly and the hip roof will end up above the gable roof.  Unless the image is deceiving.
Fri, Jun 7, 2013 at 7:48:39 AM | Additional Roof will not attach to original roof
fgibase4
4 Stars: 1 Votes
That actually solved the first problem. Thanks! Sorry, I am new to revit and am having to crash course it in a very short time. I adjusted the slope of the roof, but I get a new error now when I use the roof join command. Any suggestions?
Fri, Jun 7, 2013 at 7:48:54 AM | Additional Roof will not attach to original roof
SteveB
3.5 Stars: 5 Votes
I agree, that's the problem:  the blue roof will not acuatlly resolve to the main roof.  change the pitch of the blue roof
Fri, Jun 7, 2013 at 7:50:59 AM | Additional Roof will not attach to original roof
fgibase4
4 Stars: 1 Votes
I essentially want the new roof to be "extended" into the gabled roof, if that is possible.
Fri, Jun 7, 2013 at 7:56:40 AM | Additional Roof will not attach to original roof
fgibase4
4 Stars: 1 Votes
I figured it out. I needed to remove the slopes from the two opposite sides of the roof. I am a dummy.
Thank y'all for your help and quick responses!
Walls won't attach to roof
Wed, Nov 26, 2008 at 4:43:18 AM
Attach Wall up to Roof
Tue, Oct 2, 2007 at 3:57:57 AM
walls wont attach to new roof
Mon, Nov 18, 2013 at 3:57:45 PM
Problem: cannot attach truss top to the roof
Fri, Oct 26, 2012 at 4:43:31 AM
Is there a way to subtract roof geometry from wall - Take a look at attachment
Thu, Feb 9, 2012 at 2:59:43 AM
Page generation time: 1.7407
