Forums >> Revit Building >> Technical Support >> Is there an easier way to create surface/fill paterns?
Mon, Feb 6, 2006 at 4:54:00 PM | Is there an easier way to create surface/fill paterns?
I8cookiemonster
I8cookiemonster Avatar
I'm currently looking for an easier way to create surface patterns in Revit. Currently the only method I know of is to create a text file with the extension *.pat. That is fine for very simple surface patterns, but does anyone know if there is a way I can draw the pattern I want and save it instead (or any other way that doesn't require me to use Notepad...)?
Mon, Feb 6, 2006 at 4:58:18 PM | RE: Is there an easier way to create surface/fill paterns?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As mentioned probably around 15 times on this site already.... HatchKit. Sorry i get frustrated answering the same question over and over.
Thu, Nov 30, 2006 at 4:37:33 PM | Is there an easier way to create surface/fill paterns?
belyo
using a third party software should hardly be considered "an answer" i thought revit was bim software...
Thu, Nov 30, 2006 at 5:52:00 PM | Is there an easier way to create surface/fill paterns?
framerman
4 Stars: 13 Votes
hatchkit
Fri, Dec 1, 2006 at 9:21:19 AM | Is there an easier way to create surface/fill paterns?
coreed
coreed Avatar
4 Stars: 16 Votes
Hatchkit
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fill Paterns
Wed, Jan 31, 2007 at 12:17:30 PM
Revit fill/surface patterns for 2011
Tue, Oct 19, 2010 at 1:33:20 PM
Cut Fill Paterns
Mon, Oct 2, 2006 at 4:05:04 PM
Topographic surface Fill cut control
Fri, May 6, 2011 at 10:23:50 AM
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
Page generation time: 0.6758
