Forums >> Community >> The Studio >> Is there any way to download all the families at once?
Tue, Jun 1, 2004 at 2:43:09 PM | Is there any way to download all the families at once?
springdr
I see we have at our disposal quite a few families available to download. Is there any way to download them in bulk as opposed to one by one for all 1700 of them. This seems an incredibly tedious and inconvenient way to do things. Thanks in advance. Donald
Tue, Jun 1, 2004 at 6:08:00 PM | RE: Is there any way to download all the families at once?
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Unfortunately this is easier said then done... Since the list of families is dynamic and changes daily, we would have to dynamically create zip files of an incredibly large size to make this work. This would also create an major bandwidth load on the server. Our search system makes it easy to come by and download the family you need when you need it. Also, we try to encourage our members to visit often and be involved with the community instead of milking it once and never coming back. Thank you for your input.
Hiroshi Jacobs
Sat, Mar 22, 2008 at 3:17:11 AM | Is there any way to download all the families at once?
amitjersy
Cabinet Files Installation Error while installing RAC 2008
After accepting License Agreement, When I press Install button to install the "Cabinets File" then "Content Extraction Dialog" reports the following errors abut errorneous cabinets, Pressing Skip or Retry doesnt solve error: -
Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\ENUHelp.cab"
When I press Skip, then other error appears: -  Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\IntMetTempl.cab"
When I cancel Cabient installation process then, a dialog appears that RAC 2008 is successfully installed but when I run the application then it give error that - "AccuRender rendering feature is not available because the Accurender library could not be found on your computer. Please check the AccuRender resource path set in settings> Option dialog"
After it another error appears that the default template file specified in the "File Location" section of the> Setting>Options Dialog (C:\Document & Settings\All User\Application Data\Autodesk\RAC 2008\Metric Templates\DefaultUs-Canada.rte) does not exist. Other error appearas that: - Some of the Revit Content that you chose to install was not successfuly installed, do You want to try and install the content again. When I press Yes to install the require content then the same error occur that: -
RAC is installed porperly but except the Templates & Cabinet files. I checked in RAC 2008> Settings>Options>File Location>Default Template File then Press Browse for looking of defaultUS-Canada.ret, But this template is not exist.Pls tell how to install cabients file without any error.
Mon, Mar 24, 2008 at 5:53:43 AM | Is there any way to download all the families at once?
JHanby
3.5 Stars: 3 Votes
Quoting hjacobs from 2004-06-01 18:08:00
"... Our search system makes it easy to come by and download the family you need when you need it. ..."
I would have to disagree with this statement.  I think the search could use a little tweaking to make it better.
Fri, Mar 28, 2008 at 1:00:52 PM | Is there any way to download all the families at once?
KingRevit
4 Stars: 12 Votes
i have all the famlies on a dvd's along with about 2000 of my own ones i can send anyone a copy if you send me $1000.
Dont know how to download families
Wed, Jan 31, 2018 at 11:50:15 AM
12
Can't use any of the families I download from this site :(
Fri, Nov 27, 2020 at 4:28:12 PM
Can't donwload families
Tue, Jan 19, 2016 at 9:51:12 AM
Bulk download of Residential Families
Tue, Dec 10, 2019 at 7:25:05 AM
Issues with loading downloaded families
Thu, Jan 9, 2014 at 12:11:36 PM
Page generation time: 0.2696
