21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> Fence
6 Posts No Rating |
Hello,
To draw a fence i used Railing. How i can change it now to a timber fence? Thank you.
Just assign a tmber material to the elements in your fence.
6 Posts No Rating |
I couldn't find where i can assign a new material, in "Edit Type" there is no option to change material. So I just downloaded timber fence from RevitCity and placed it instead of railling.
Anyway thank you for the reply.
Once you hit edit type you need to Edit the Rail Structure and apply the material in there. Balusters need to be assigned in the actual baluster family that is being used. If you can't figure something out its always best to look around for the answer instead of just giving up and going with something else because its the only way you will learn for next time.
Fence |
Mon, Jun 15, 2009 at 11:27:20 AM
Fence |
Fri, Aug 3, 2007 at 11:00:10 AM
Parametric Fence Families |
Wed, Dec 21, 2016 at 1:48:27 PM
The Hard Way to Create a Topo Fence - But it Works. |
Mon, Nov 10, 2014 at 2:19:00 PM
Chainlink Fence |
Fri, Aug 9, 2013 at 4:51:55 PM
