Forums >> Revit Structure >> Technical Support >> Joist dissapears on plan but is there
Mon, Jun 3, 2013 at 1:36:37 PM | Joist dissapears on plan but is there
sblake
I am putting joists in and if the span is shorter than 10', they dissapear on the plan. They are still there in the model when I cut a section. Any ideas? I am not getting any errors  and I put them in using a beam system.
Revit 2012
Mon, Jun 3, 2013 at 1:38:31 PM | Joist dissapears on plan but is there
Joists are flat - not sloping?
Where is plan cut plane?  & Joist elevation?
Mon, Jun 3, 2013 at 1:55:23 PM | Joist dissapears on plan but is there
sblake
Joists are sloping... I have attached two screen shots. It seems to have something to do with the span of the joists, because some are showing up and some are not. They are all at the same slope.
You can see the joists are there in the section...
Mon, Jun 3, 2013 at 2:10:43 PM | Joist dissapears on plan but is there
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure they are at the same elevation? Attach an image of the section?
Mon, Jun 3, 2013 at 2:27:26 PM | Joist dissapears on plan but is there
Tea - the section is shown to the right.
sblake - show us an elevation section parallel to the joists that just shows two of them - the short one to the right and the l;onger one just to the right of that.  Include a line in the section to show where this plan's cut plane is.
Mon, Jun 3, 2013 at 2:27:56 PM | Joist dissapears on plan but is there
sblake
I did attach the image of the section. They are on the same reference plane
Mon, Jun 3, 2013 at 3:06:34 PM | Joist dissapears on plan but is there
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Sorry I did not see the first section.
Mon, Jun 3, 2013 at 3:12:58 PM | Joist dissapears on plan but is there
sblake
That's alright.. I just hope to get any ideas of how to fix this.. very frustrating!
Mon, Jun 3, 2013 at 3:43:34 PM | Joist dissapears on plan but is there
Make sure they are not in a different workset / DO / phase or something silly like that.  (Also plan region)
This may be like our short wall problem in architecture - a view range issue.
Or ... maybe a file corruption.  Did you try placing similar elements in a test file with the same view setup?
Mon, Jun 3, 2013 at 3:52:20 PM | Joist dissapears on plan but is there
sblake
No, I have not done a test. I put these in using the beam system, so they should all be on the same workset.
I'll keep working on it...
Mon, Jun 3, 2013 at 6:53:17 PM | Joist dissapears on plan but is there
#11
Manny
3.5 Stars: 6 Votes
change your view discipline to coordinations or change your view detial to medium.
New Joist Family not visible on plan
Thu, Jul 19, 2007 at 9:05:27 PM
Joist symbolic cutback
Tue, Oct 27, 2009 at 3:34:03 PM
AAARRRGGGHH! Joist questions! [ 1 2 3 ]
Fri, Nov 18, 2011 at 9:13:38 AM
37
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:46 PM
13
Sloped joist line type
Thu, Nov 25, 2010 at 12:25:02 PM
Page generation time: 0.3586
