Forums >> Revit Structure >> Technical Support >> Views from project/sheet have disappeared
Fri, May 31, 2013 at 11:08:20 AM | Views from project/sheet have disappeared
crosado
i have been working on a project for several months. a few months back i created new section cuts on a plan; these cuts were then added to a new sheet. i clouded the new section cuts and the new sheet.
now i just noticed that the new section cuts have completely disappeared from the plan and from the new sheet. all that remains are the clouds and the new sheet. what has happened?
Fri, May 31, 2013 at 11:22:42 AM | Views from project/sheet have disappeared
How would we know?  Obviously you have done something.\
  1. In your browser, are the views still listed under the sheet when you expand the listing?  If so, then they may have been moved out in "space" on the sheet.  Another way to see this is do the callouts still show the sheet?
  2. If the views are not in space, then do they still exist.  If the callouts are there but the callouts are blank, then someone deleted them from the sheets - just put them back.
  3. If they views are completely gone, then someone deleted the view from the bowser or deleted the view by deleting the callout.
missing sheet in project browser
Fri, Aug 22, 2014 at 7:13:58 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
Move several views to another sheet
Wed, Apr 13, 2011 at 4:20:32 PM
Annotate in Sheet Views ONLY
Tue, Apr 27, 2010 at 9:17:12 AM
Page generation time: 3.4241
