Forums >> Revit Building >> Technical Support >> Duplicate Section Cuts
Mon, Feb 6, 2006 at 12:58:17 PM | Duplicate Section Cuts
OzMan
I would like to show the same section or detail cut on several spots on my plan. In other words, the same symbol with the same detail number and sheet number in various places where the conditions are the same. I copied the symbol and moved it a different location, but Revit would not allow me to use same numbers. What do you do when you want to indicate that another cut is "similar" to a previous detail? Thanks
Mon, Feb 6, 2006 at 1:01:09 PM | RE: Duplicate Section Cuts
rberliner
Click the section on the Design Bar, and before placing it, select the "refernce other view" on the options toolbar and select the detail that it keys to.
Mon, Feb 6, 2006 at 1:08:55 PM | RE: Duplicate Section Cuts
OzMan
That was easy, thanks Rberliner for the quick reply.
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:27 AM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:44:59 AM
Section cuts WAAY too deep!
Tue, Jun 7, 2011 at 5:34:55 AM
Rouge sections cuts
Wed, May 2, 2012 at 4:07:32 PM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
Page generation time: 1.1142
