Forums >> Revit Building >> Technical Support >> Converting associated levels to non plan view level
Fri, May 31, 2013 at 7:23:59 AM | Converting associated levels to non plan view level
hamed60
Hi,
I have accidently created some associated levels with view plans, which I don't need to appear in my project browser under floor plans and so on. Is there a way to chage them to non assoiated levels (so that you have a black level head instead of the blue one) so that I don't see them anymore.
Thank you!
Hamed Torakai
Fri, May 31, 2013 at 7:49:51 AM | Converting associated levels to non plan view level
A level will show up in views no matter if it has associated plans or not.   We often have levels that don't have plans .... like Top of Wall (Parapet)... Top of Steel .... or other references.
To make a level black (no reason to do this) - delete the associated plan view.  Hide the level if you don't want to see it.
Fri, May 31, 2013 at 8:05:04 AM | hamed60
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting hamed60 from 2013-05-31 07:23:59
Hi,
Thank you!
Hamed Torakai
https://chronicle.autodesk.com/Main/Details/2c1913aa-3615-413b-8cd8-74376c7f01da
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, May 31, 2013 at 12:37:05 PM | Converting associated levels to non plan view level
hamed60
Thnx Coreed,
This is exactly what I wanted.
Hamd Torakai
Sat, Jun 1, 2013 at 7:17:19 AM | hamed60
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting hamed60 from 2013-05-31 12:37:05
Thnx Coreed,
Hamd Torakai
Your Welcome
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Plan view levels
Tue, May 5, 2009 at 3:15:03 PM
Select All Objects by Referenced Level?
Mon, Jun 5, 2006 at 5:14:28 PM
Placing Electrical on Walls of different levels that are in same view
Thu, Mar 5, 2015 at 9:41:25 AM
view depth without dims
Thu, Jan 15, 2009 at 11:27:04 AM
Full edit capabilities insiide plan region
Thu, Dec 8, 2005 at 4:13:57 AM
Page generation time: 0.7758
