Forums >> Revit Structure >> Technical Support >> Vertical bracing line
Fri, May 31, 2013 at 3:52:05 AM | Vertical bracing line
curtins1
In my project template, i have my detail level set to medium in plan views. When i model vertical bracing i want to show a dashed line to show the vertical bracing position in plan just like if i was to set my detail level to course.
Im really looking to see how everybody else goes about this ?
Do you add a model to youre beam family so it shows up in plan  ? or do you just draw a detail line in plan to show vertical bracing position Cryingdont really think this is the right way because if youre bracing moves the line wnt move with it) or is there a way to make youre beam family show up in a course view in a medium detail level ?
hope this makes sense ! Just want to know what the best way is going about this ?
Can anybody help ?
Thank you
Fri, May 31, 2013 at 7:09:42 AM | Vertical bracing line
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to edit the family and select what you want to see and in your Properties under Visibility/Graphic Overrides chose the scales at which you want the object to show.  If you just want the symbolic line to show at medium click on it and choose corse and medium and then click on the extrusion and change it so it only shows in fine detail.
Fri, May 31, 2013 at 7:23:19 AM | Vertical bracing line
curtins1
Can you show me a picture on how to select the symbolic line in a beam family ?
Fri, May 31, 2013 at 7:28:57 AM | Vertical bracing line
curtins1
do you have to draw a new symbolic line in the beam family ?
Fri, May 31, 2013 at 9:55:36 AM | Vertical bracing line
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The lime green lines are the symbolic lines.  These are already built in to the out of the box revit families (depening on what family you are using). If you created your own family you will need to add the symbolic lines.
Sun, Jun 2, 2013 at 2:17:03 AM | Vertical bracing line
kathey1
the symbolic line does not show up if one end of my bracing is higher than the other (diagonal bracing).
It only shows up if the bracing is level.
Is there a way to make the symbolic line show up with diagonal bracing ?
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Revit 2014 Vertical Bracing Problems
Thu, Feb 20, 2014 at 10:26:00 AM
vertical bracing problem / bug
Wed, Jan 18, 2012 at 3:13:12 AM
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:38 AM
Vertical bracing in plan question
Wed, Sep 26, 2012 at 1:01:35 AM
Page generation time: 1.7088
