Forums >> General Discussion >> Revit Project Management >> Cannot edit cut on stringer
Thu, May 30, 2013 at 9:34:39 AM | Cannot edit cut on stringer
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I am drawing up a basic staircase and want the stringer on the landing to join the stringer on the two stair runs seamlessly, please see the image for what i caurrently have and the red lines indicate the way i want the stringers to look.
I am using Revit Arch 2013.
Many thanks,
CM.
DON'T WORRY, I'VE FOUND WHAT IT WAS. THE ENTIRE STAIR NEEDS TO BE CREATED IN ONE OPERATION WITH TWO LANDINGS THAT AUTOMATICALLY JOIN RATHER THAN SWITCHING TO A LANDING  RUN DURING CREATING TWO STAIR RUNS.
Edited on: Thu, May 30, 2013 at 10:11:19 AM
Thu, May 30, 2013 at 9:52:53 AM | Cannot edit cut on stringer
Check your stair properties - stringers - "Trim stringers at top" - match landing stringer.
Tue, Aug 6, 2013 at 4:31:40 PM | Cannot edit cut on stringer
kkohutek
kkohutek Avatar
4 Stars: 7 Votes
Hello!
Chunkymonkey, I'm using RAC 2013 too, and I'm having the same problem with my stringers.
Correct me if I'm wrong, but I thought you managed to make it work by creating two landings separately in the same operation, and they would join automatically. That's right? Is it stairs by run or by sketch?
I tried it (stair by run), and if it's not what you had in mind is probably my dumb mistake, but I get an error message about invalid parameters when finishing the second landing (as attached below).
Am I too far from home?
Edited on: Tue, Aug 6, 2013 at 4:32:32 PM
STAIRS - Stringer & Handrail Cut
Mon, Nov 1, 2010 at 8:06:54 PM
Stair Stringer with Horizontal return to floor
Thu, Oct 10, 2013 at 7:35:28 AM
Stringer Haunch (level off) at top of flight
Wed, Dec 14, 2011 at 2:03:06 PM
Stringer as rail profile problem
Tue, Mar 25, 2014 at 8:27:14 AM
Inserting stringer profiles
Wed, Mar 5, 2014 at 7:23:53 AM
Page generation time: 0.3950
