Forums >> Revit Building >> Technical Support >> Render problem
Tue, May 28, 2013 at 6:11:06 AM | Render problem
Wolfishfish
Hello. I want to render my isometric view but it says there si not enough space on disk C and that it requires 500 gb more. But, when I render my image (with high quality to printer with resolution of 150) it renders without problems.
So I have 2 questions:
1) Why I can't render isometric view while I can render interior perspective with the same quality?
2) How come it requires 500 more gb, what can I do?
Wed, May 29, 2013 at 12:22:06 PM | Render problem
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
It needs 500 GB ?? That's completely insane.
Most hard drives aren't even close to that in total.
Something here you're not telling us with regards to what you are rendering, the materials and or the settings.
Wed, May 29, 2013 at 12:28:08 PM | Render problem
rod23
5 Stars: 4 Votes
It's because your default 3D view is at 1:1 scale and trying to render a real world size image, probably a couple hundred feet wide.  Copy the view and change the scale, or set up a camera.
http://www.turbosquid.com/Search/Artists/Revitaoist
Thu, May 30, 2013 at 12:37:29 AM | Render problem
Wolfishfish
Thank you guys, that sounds logic, I knew there is smthg wrong. I v changed the scale from 1:1 to 1:1000, and it works. But I want to ask will changing the scale affect the quality of the rendered image?
Render in Cloud Problem
Fri, May 24, 2013 at 8:19:23 AM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
New Render Appearance
Tue, Jul 6, 2010 at 9:45:22 AM
Wooden floor render problem - how to change direction of flooring???????
Fri, Mar 18, 2011 at 2:42:49 PM
Missing Render images
Sun, Feb 12, 2012 at 7:36:48 AM
Page generation time: 1.4646
