Forums >> Revit Building >> Technical Support >> copying system panels between projects - how should it be done?
Mon, May 27, 2013 at 6:48:51 PM | copying system panels between projects - how should it be done?
danezeq
i want to copy those system panels to another project. how can i copy it without copy the elements? (which gonna copy the levels with them if i'll do it that way..)
Tue, May 28, 2013 at 1:27:01 AM | danezeq
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-05-27 18:48:51
use Transfer Project Standards in Manage tab.
want more?
You can get more tips at Enjoy Revit
Tue, May 28, 2013 at 6:21:35 AM | copying system panels between projects - how should it be done?
danezeq
Thank you.
i tried it - and it copied the materials, but this command doesn't copy SYSTEM PANELS?
any other way to copy system panels between projects?
Tue, May 28, 2013 at 6:31:10 AM | danezeq
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-05-28 06:21:35
Thank you.
Did u do at the new project? U hav to do it in the new project like importing.
want more?
Tue, May 28, 2013 at 12:05:33 PM | copying system panels between projects - how should it be done?
danezeq
Yes.
I went to the NEW project and clicked on Mange tab >> transfer project standarts
Tue, May 28, 2013 at 7:50:47 PM | danezeq
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-05-28 12:05:33
Yes.
you have to make a curtain wall type that using the panels you made, before transfer.
it doesn't work for only panels.
want more?
Wed, May 29, 2013 at 6:58:56 PM | copying system panels between projects - how should it be done?
danezeq
How can i import from the project all what needed togther to use those curtain walls in my project?
Wed, May 29, 2013 at 7:03:30 PM | copying system panels between projects - how should it be done?
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Or just copy & paste. It's simple and works all the time.
want more?
Wed, May 29, 2013 at 7:06:51 PM | copying system panels between projects - how should it be done?
danezeq
yes. that's right. but i'm afraid to do it beacuse it copyies levels which i don't need in my project and im afarain it'll change constrains etc..
Wed, May 29, 2013 at 7:18:16 PM | danezeq
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-05-29 18:58:56
1.  make curtain wall types using the panels you made
2. open the project you want new panels move to
3. transfer curtain wall types from you already made
4. then you can see all curtain wall types and system panels at project browser in your new project...
it's not very difficult.... am i missunderstanding something?
want more?
Wed, May 29, 2013 at 7:46:24 PM | copying system panels between projects - how should it be done?
danezeq
Im not sure if i understand you right.
the problem as i guess, is that revit doesn't transfer the materials with the panels - so they're not colorful in the new project.
here is a video:
http://www.youtube.com/watch?v=LsyKdmWxOTI
Wed, May 29, 2013 at 8:04:09 PM | copying system panels between projects - how should it be done?
danezeq
There is a problem more before.
i can't even make new colored panels in the ORIGINAL project.
now i'm confused
http://www.youtube.com/watch?v=LnVsTxYn4ms
Wed, May 29, 2013 at 8:12:21 PM | copying system panels between projects - how should it be done?
#13
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
well, i think i see what is wrong..
can you upload the project file with the panels?
then i'll show you what the worng is and how to figure it out.. in video just like you did for me..Smile
want more?
Wed, May 29, 2013 at 8:17:53 PM | copying system panels between projects - how should it be done?
#14
danezeq
Ofcourse
Wed, May 29, 2013 at 8:41:33 PM | copying system panels between projects - how should it be done?
#15
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
watch this
http://youtu.be/eLOcvOdJqOU
want more?
Can't delete Glazing or System panels in Revit Structure
Wed, Apr 17, 2013 at 9:57:51 AM
How to remove system panels from my project
Wed, Dec 12, 2007 at 2:21:57 PM
Copying callouts across the projects
Thu, Dec 4, 2014 at 9:59:11 AM
13
copying assemblies between projects
Fri, Jun 1, 2012 at 10:39:32 AM
Analytical construction of system panels
Mon, Feb 16, 2015 at 8:29:52 AM
Page generation time: 1.0140
