Forums >> Revit Building >> Technical Support >> revit won't render in 3d
Mon, May 27, 2013 at 3:17:48 PM | revit won't render in 3d
Wolfishfish
Hello. I have designed my building and what I wana do now is to show each floor in 3d view, smthg like isometric view. I m using section box to eliminate upper floors. The problem is that when I start rendering to printer the image becomes white, and the rendering takes few seconds. But if I m rendering to screen it can render. But I need to render to printer with higher resolution. Any suggestions? thanks in advance.
I m attaching jpeg: upper image shows rendered image when I set resolution to printer, and the lower shows it to screen
Tue, May 28, 2013 at 7:18:05 AM | revit won't render in 3d
System?  Memory?  Which Revit?  All latest updates installed?
Tue, May 28, 2013 at 11:23:56 AM | revit won't render in 3d
Wolfishfish
Windows 7(64 mb). revit 2012. But I m not aware about updates, do I need to constantly update my revit? I know this is a noob question..Buy the way I have 250 gb free space on disk C, which I think should be ok for rendering. Is it an update problem?
Tue, May 28, 2013 at 12:15:48 PM | revit won't render in 3d
You should always pay attention to news about updates.  AutoDESK will continue to update a release until a new release is formalized.  I show my Release 12:
20110916_2132(x64)Update Release 2
You might have to turn off hardware acceleration.  Revit R pulldown / options / graphics.
Tue, May 28, 2013 at 12:44:52 PM | revit won't render in 3d
4 Stars: 205 Votes
Try to clean your TEMP folder, use "CCleaner" or similar software.
Wed, May 29, 2013 at 4:40:54 AM | revit won't render in 3d
Wolfishfish
thank you for suggestions. One more question- if I turn off my hardware aceleration what will happen? What is the purpose of this option?
RPC's won't render in 3DS Max after importing from Revit
Sat, Dec 17, 2005 at 9:10:50 AM
Mullions won't render
Wed, Jun 24, 2009 at 4:09:30 PM
Lights won't turn on for exterior render
Wed, Mar 16, 2016 at 6:03:04 PM
Images won't render!
Thu, Sep 4, 2008 at 3:36:22 PM
Help - My render won't export
Thu, Dec 18, 2008 at 10:54:52 AM
Page generation time: 4.6497
