Forums >> Revit Building >> Technical Support >> why my wall top and botom are always not accorrding to the level which I drew
Mon, May 27, 2013 at 8:40:35 AM | why my wall top and botom are always not accorrding to the level which I drew
fairywiner
I have a very agnoy problem, I am using revit drawing a project, some wall types when I draw always not related to the levels on which I drew. For example if I draw a wall on level one, I would like the wall top is on the level two, the botom of the wall is on the level one, and there is no top offset or bottom offset unless I intentionally set them.
But now when I draw  wall, it alway goes to unrelated level and unreasonable top or bottom offset, and I have to adjust manually one by one , that 's reall annoying.
See the picture, I drew on 02 skywalk level, but the wall properties shows the bottom of the wall is on 01 street level. the top offset is 27'6"
my question maybe too easy, but I really agnoied by it.
沧海月明珠有泪
Tue, May 28, 2013 at 1:38:59 AM | why my wall top and botom are always not accorrding to the level which I drew
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
may be you changed work plane sometime before..
you have to reset work plane at the view you want to work at, before you draw walls.
after change work plane in a view, the work plane is not going to be changed unless you change it again at the view.
Edited on: Tue, May 28, 2013 at 1:39:20 AM
Edited on: Tue, May 28, 2013 at 1:40:01 AM
want more?
You can get more tips at Enjoy Revit
Tue, May 28, 2013 at 8:35:08 AM | why my wall top and botom are always not accorrding to the level which I drew
fairywiner
but didn't the default workplane should be the level at which you draw?
沧海月明珠有泪
Tue, May 28, 2013 at 8:52:57 AM | why my wall top and botom are always not accorrding to the level which I drew
How did you create that plan view?  If you just copied another plan and changed the name, then that is your problem.  Create the plan from the view tab.
Overhead wall and Level 3 are not aligned
Thu, Mar 17, 2016 at 10:17:42 AM
Continuous walls from ground to roof - not separated by floor
Tue, Jul 5, 2016 at 5:41:14 AM
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:13 PM
Adding Base Level & Top Level to a column tag
Wed, Mar 13, 2019 at 9:37:05 AM
Walls not attaching to the correct level
Mon, Jun 10, 2013 at 8:10:59 AM
Page generation time: 0.8368
