Forums >> Revit Building >> Technical Support >> plan view changes
Sun, May 26, 2013 at 12:47:25 PM | plan view changes
Warchitect
4 Stars: 5 Votes
my up high window needs a plan region to be see able on the layout. but as you can see, a wall is also being cut. but when I move the plan region edge closer to the windows, the windows disappear. see both images for a before and after. note the plan region is not even close to the edge of the window in either scenario,
Sun, May 26, 2013 at 5:04:57 PM | plan view changes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Make your plan region narrower so its not crossing that wall.. otherwise change the top constraint so that its above the window if possible
Sun, May 26, 2013 at 7:49:07 PM | plan view changes
Warchitect
4 Stars: 5 Votes
what you said doesnt make sense. the problem is not the wall thats incidental, its the windows....they disappear! moving the edge of the plan region closer to the wall is the problem.
Sun, May 26, 2013 at 8:05:53 PM | plan view changes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I miss read your problem. So why are u moving it closer to the wall if it works one way? Eitherway I would assume that there is a reference line in the family that is not being picked up when u move the plan region closer, I believe the entire family needs to be in the plan region in order to show
Sun, May 26, 2013 at 8:27:48 PM | plan view changes
Warchitect
4 Stars: 5 Votes
So I stripped it down.
tell me how you get the plan region to be against the wall hosting the window...it works on the window on the left...why does the window on the right go blank.
Tue, May 28, 2013 at 8:48:53 AM | plan view changes
I played around with that family and I could not find out what was wrong.
I checked for nested families, voids, invisible lines, reference lines - but could not find out what it was.   But it is that family.  I would send it to AutoDESK and see what they would come up with.
Tue, May 28, 2013 at 11:01:27 AM | plan view changes
Warchitect
4 Stars: 5 Votes
Thanks for the try Hub.
Ill send it
Michael
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 1:27:29 PM
Plan view levels
Tue, May 5, 2009 at 3:15:03 PM
PLAN REGION PROBLEM
Wed, Sep 10, 2014 at 11:15:22 AM
11
Beams showing above in plan view
Thu, Sep 4, 2008 at 11:18:12 AM
Sections not Showing in Plan View
Mon, Oct 28, 2019 at 4:42:02 PM
Page generation time: 4.1560
