32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Coping Views between Revit projects. is it possible?
hello everyone
I have a project in two different version. everyone of them is on diffefent file.
i want to take a 3-d view from one project and copy it to another.
i tried Insert>>inser from file>>insert views from file
but it support only drafting views. (which i don't know what is it)
so is it possible?
thank you :-)
2 Posts No Rating |
Hi...
yes it is possible to copy 3d views from one file to another...
go to your 3d view => select the crop line => directly open a plan view => you would see a camera selected; copy the camera and paste it into the same plan level in the other file!
you talk only about perspective views no?
i'm talking about the 3D default view (which is not camera. it's isometric view)
i want to copy the exact angle of the 3-d default view.
i worked on it and found that IT IS aply on regular 3d view which is owsem! thank you!
but sill it doesn't keep the zoom from the other project.
Revit doesn't save the zoom ever but you can always save the zoom by right clicking on the viewcube > set current view as home and then is saves the zoom.
i need this zoom the make exact same render from two seperate projects.
so - is there anyway to take that spesiphic zoom from one project to another?
thanks! :-)
Truss - coping frame members |
Mon, Aug 16, 2010 at 5:51:35 AM
Finish Profile at Stone Coping [ 1 2 ] |
Tue, Jul 29, 2008 at 1:20:47 PM
16
using views in other revit projects |
Sun, Nov 21, 2010 at 2:23:26 PM
How can I radius my coping of steel beams? |
Mon, Oct 25, 2010 at 5:02:18 PM
Loading coping stones into the model |
Fri, Feb 12, 2010 at 6:17:14 AM
