Forums >> Revit Building >> Technical Support >> Making Lights Work
Sun, Feb 5, 2006 at 8:02:12 PM | Making Lights Work
brinkhoffs52
I downloaded a file from the lighting family here (School-house light-211) and i placed it in my model. However when i render the view the lights dont emit any light. I have the watts and lumens as postive numbers. Is there something im missing? The lights are hanging from the roof (they arent in a ceiling) is that causing the problem? Help would be greatly appreciated.
Sun, Feb 5, 2006 at 10:54:13 PM | RE: Making Lights Work
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you sure its not emitting any light or are the materials applied to the light not indicating as such? If there is no light being emitted check your rendering settings and make sure you have the light source turned on in your lighting tab. If the light is emitting light but still showing grey, edit its material to be something more reminiscent of a glowing light. HTH.
Thu, Sep 13, 2007 at 1:35:48 PM | Making Lights Work
galina
if everything fine with the light material check
if you have exterior or interior scense checked<you said it's hanging off the roof,meaning it's out side
under you rendering-lighting-check your lighting list (on and off)
Lights
Tue, May 29, 2012 at 5:02:26 AM
exporing revit 09 to 3ds max with lights???
Tue, Jun 2, 2009 at 5:53:27 AM
lights on sloped roof plane?
Fri, Sep 13, 2013 at 8:04:45 AM
Ceiling Lights don't self-illuminate
Mon, Oct 17, 2011 at 10:21:44 AM
Interior Lights are not working in Rendering
Wed, May 5, 2010 at 12:33:18 AM
Page generation time: 5.7788
