Forums >> Revit Building >> Technical Support >> DIMENSIONING WALL ENDS
Sat, May 25, 2013 at 2:33:50 PM | DIMENSIONING WALL ENDS
mongopac
Apparently, Revit will not all me to dimension the FOS of the ends of walls if I enable wrapping.  It  seems as though it always goes to the outer end of the wall, which is to say, the finished face, however it is I may organize the wrap.
Is there a way to get it to dimension to the face of the core?
Currently I just draw a little line at the FOS (the line won't even snap to the core, BTW) and dim to that, but of course that isn't very useful if the wall needs to be moved around.
Tue, May 28, 2013 at 1:47:40 AM | DIMENSIONING WALL ENDS
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
as i know, wall end wrapping(and insert wrapping) option is a kind of tricks in revit programing,
it doesn't infuluence any other datum except plan views, it means revit can't recognize core face at the end of the wrapped walls.
the way you use is not bad, or you have to make two seperated single walls-core & finish
Edited on: Tue, May 28, 2013 at 8:16:44 PM
Edited on: Tue, May 28, 2013 at 8:17:46 PM
want more?
You can get more tips at Enjoy Revit
Wed, May 20, 2015 at 12:34:43 AM | DIMENSIONING WALL ENDS
purgeme2
It is a very frustrating flaw in revit, i have had the same issue over and over and we find ourselves in 2016 with no answers.
Wed, May 20, 2015 at 8:49:23 AM | DIMENSIONING WALL ENDS
I dimension to the face of walll and note that it is FIN in the dimension.
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:57 PM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
Wall Ends No going to Gridlines
Fri, Apr 9, 2010 at 2:04:02 PM
Revit 2008 - Dimensioning Curtain Wall
Tue, Feb 19, 2008 at 5:26:46 PM
Adjust Wall Ends
Wed, Jul 10, 2013 at 9:08:25 AM
Page generation time: 5.8869
