Forums >> Revit Systems >> Technical Support >> about door tag
Sat, May 25, 2013 at 1:01:12 PM | about door tag
santu
can we change the doors tag's name by changing one door tag as we change in windows tag?
Sat, May 25, 2013 at 1:25:38 PM | about door tag
There are instance properties and type properties that can be used with Revit families.  Your window tags are set to read a type property.  Thus all types are set the same.  Typical door tags read the instance property.  You can edit the tag to read the type property instead but be aware of what you are doing because this is not typical.
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM
Page generation time: 0.2289
