Forums >> Revit Structure >> Technical Support >> Can you match a mesh to another?
Fri, May 24, 2013 at 4:02:52 AM | Can you match a mesh to another?
mrnavi
Hi there,
So i have a large topography in rhino but my focus is on a smaller part of the large topography. I want to bring in that large topography into revit as dwg then make it a topo just for rendering purposes. ANd i would like the smaller cutout of the topography to be the one i work with in revit (so it doesnt lag). How do i match these up?
If i import them together they cant be separated. if i import them separetly i cant place the smaller piece into the big piece correctly.
Someone please help me
Tue, Jun 4, 2013 at 11:43:02 PM | mrnavi
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting mrnavi from 2013-05-24 04:02:52
Hi there,
export it to dwg and open it in autocad, and erase  everything except the part you want, and import it in revit and make it topo..
or just delet points that you don't want to use, just after you get the points from dwg in revit..
and you have to understand that when make topo with dwg, revit recognize only endpoints of lines, and convert them to points of revit topo..  and after you make topo, imported dwg has no relation with revit topo.
want more?
You can get more tips at Enjoy Revit
Wed, Jun 5, 2013 at 6:30:19 AM | Can you match a mesh to another?
coreed
coreed Avatar
4 Stars: 16 Votes
Maybe this can be of Help also:
http://www.youtube.com/watch?v=_K1zvaiymn4
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 7:42:42 PM
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Mesh not rendering to scale???
Mon, Feb 15, 2010 at 12:43:01 PM
Page generation time: 0.3855
